I renovated my 1994 Jayco Sprite from top to bottom, including resealing every seam on the exterior, replacing all external fastenings and attachments, priming and painting, then, with the help of a friend, adding art, to make it one unique little van. On the interior it was primed and painted throughout, new splashback, sink, tap, benchtops, upholstery, handles and knobs, vinyl plank flooring, curtains, water pumps, 12 volt system, lights, and all switches and power points. I also built a conversion frame to enable the two singles to become one double. It was like a new van.
Materials
EXTERIOR::
Truck and Car Wash
Turpentine
Diggers Acetone
Sikaflex 521-UV
Frogtape Masking Tape (green)
Poly Paint Stripper
Cling Wrap
Crommelin's Exterior Grade Waterproofing and Fabric Membrane
Globalcote Primer and Infracote
Dulux Etch Primer - exterior
Dulux Weathershield Maxiflex in gloss - white for top of exterior, and Dulux 'Bluish Water' for lower
Diggers Wax and Grease Remover
White Knight Rust Guard Fish Oil for draw bar
White Knight Rust Guard Metal primer " "
White Knight Rust Guard Epoxy Enamel " " 'Shale Grey'
Truline insert moulding
Selley's Polyglaze Tyre Shine
INTERIOR:
Selley's Sugar Soap
Easy Surface Preparation (ESP)
Zinsser BIN shellac-based primer - all interior surfaces
Taubman's Paint + Primer Low sheen in Dulux colour Lexicon Quarter - walls
Taubman's Water Based Enamel in straight white - upper cabinets
Taubman's WBE semigloss 'Subiaco Sand' - lower cabinets
26 mm Merbau panel for benchtops
Selley's Original Liquid Nails
12mm Meranti for stove installation
Feast Watson Kitchen Timber Oil for benchtops
3mm ply sheets, cut into 100mm wide planks
Sikaseal Gap Filler
Pressed Metal sheet for splashback.
Bondcrete Cement Additive to prep-seal flooring
Decor8 White Penny Round tiles for table top
MDF 700mm circle panel for table top
Indian Kanthas for upholstery
Brother sewing machine
Senso Self-Adhesive vinyl floor planks
Tools
Josco Nylon Wheel on a drill
Paint Partner Reusable Sealant Edges
Scotchbrite scourers
Dewalt Table saw
Ryobi One+ jigsaw, trim nailer, driver, caulking gun, drill, sander
Bosch Sliding Mitre Saw
35mm Irwin speed bore drill bit
UniPro Microfibre 4mm nap rollers
various other handtools, brushes, rollers and trays
Sanding equipment
