Ozito 850w router will it fit the ultra 6.4mm 15 piece router bit set be compatible with the ozito router without any problems
@MitchellMc Woohooo just learnt something new 🙂
Hi again @ethan18,
I've spoken to the manufacturer, and it appears to be a case that they're just rounding up to 6.4mm instead of listing the bits as 6.35mm since the difference is negligible. I've also double-checked with Ozito that the 6.4mm router bits do indeed fit the 6.35mm collet of their machine.
Hi @ethan18,
You'll find that most 1/4 inch routers have collets that are exactly 6.35mm, and you'll also find that "1/4 inch" bits are 6.4mm. The short answer is those bits are the correct size for the router and perfectly fine to use. Basically, there are 1/4 and 1/2-inch routers and bits and I wouldn't be concerned about the 0.05mm difference as that's likely just something lost in translation between imperial and metric measurements. However, I'm now interested to know why the bits are labelled as 6.4mm, so I'll update you once I speak to the manufacturer.
Afternoon (Just) 🙂 @ethan18
I think I am a sucker for having a wander around Bunnings, but yeah It could be a good idea. Mostly because the tool staff know their stuff, they also know what is compatible and what is on their shelves atm. For instance I didnt know that they had a drill gauge hanging there next to the drill section and so many times when I have been drilling holes just trying to figure out what hole size I should drill verse screw size it would have been handy. Needless to say after talking to one of the staff and joking about my skill at not seeing things I bought one 🙂
So easier yes, learing something new yes.
So it is just going to be easier to go to Bunnings and ask them and see how well the bits Will fit ?
Afternoon @ethan18
I just googled 1/4 inch to mm and it came back to 6.35mm. Thats pretty close. I know that have a drill gauge at Bunnings stores, usually blue and located next to the drills 🙂 Half a mm is half a mm is my only concern.
The ozito router fits a 1/4 size I just need to know if that set of bits will fit it
I have just been having a look through both things and cant seem to find a mention of the shaft max size on teh 850W router. One of teh other people will probarly know more 🙂
Hello @ethan18,
Many thanks for your question about the Ozito 850W Router. I'm sure our resident Bunnings D.I.Y. expert @EricL will be happy to assist you when he's back online this afternoon.
Let me tag our helpful members @Dave-1 and @Seaton to see if they have any thoughts.
Thanks for your patience in the meantime.
Akanksha
