I’m having a rainwater harvesting setup installed on a shed so I’m looking at the pros/cons of burying pipes versus routing them above ground.
The shed is 13m X 15m with 100mm down pipes on the ends.
The water tank is located down the hill from the shed so the top of the tank is below the level of the shed foundation.
The tank is about 14m from the shed
The wet system is easier to work around and looks better with the pipes hidden but has lower flow since water pressure is needed to push water up to the tank inlet.
An online calculator indicates 32m of 100mm pipe will hold 251 liters of water before any gets pushed into the tank.
Not sure how to calculate the wet versus dry system flow rates.
One online forum indicated the water trapped in the pipe between rain events will become stale due to lack of oxygen. Anaerobic.
Sediment will collect in the buried pipe even with first flush and leaf eaters on down pipes so needs flush ports.
The dry system has higher flow but has exposed pipes that need support when routed thru the air.
Pipes from store are all curved a bit so challenging to build and support a straight 14m run to the tank.
On line forum suggested there will be maintenance issues with long above pipe runs supported on posts.
Any thoughts or experience much appreciated.
