Hello. I want to build a floating deck . It will be 5.4m × 5m and connect to an existing low level deck with a step up.The deck will be partially sit on cement pad and partially on dirt. The bearer on the cement pad will sit on a mini pedestal block and then tuffblocks with stumps when it reaches the grass after approx 500mm.
Im looking to use 90x90 H4 F7 stumps with 140x45 h3 f7 bearers and 90x45 h3 f7 joists notched into the stumps and will be spaced 45mm apart. Im trying to work out how far apart i space the bearers and the tuffblocks. The calculator to work this out is beyond me and im wondering if someone is able to advise please. Also i know with tuffblocks i should bring them in with the bearer so they dont stick out under the deck. For support do i carry out side blocking of the bearers or joists. Thanks
