Hi all,
looking for a bit of advice on how to do a French drain. I've done a bit of research on them and I'm looking to lay one down on my front yard and connect it to my stormwater pipe for some drainage as my yard slopes towards my house causing rainwater to run towards my house and sometimes puddling at the lowest point (Pink X is on picture) plus lawn feels damp even days after it has rained. Hoping to get some guidance on it and what materials to use and whether my ideas are achievable or not.
This is the current state right now. Soil has built up on the far right of the house which I know is not good at all. Im going to dig down so that it's in line with the lowest point (PINK X)
the BLUE LINE is my current stormwater pipe, and the YELLOW LINE is the ag pipe I'd like to run across my lawn. ill have to cut the concrete to do it. I'm thinking of then putting a pit where the red square is.
my question with the the above PIC 1
1. Does this look okay to do?
2. How far away from the house do I need to dig my trench? im thinking around 400mm away from the house and have the remaining soil thats near the house, slope towards the trench.
3. what width does the trench need to be and how far down do i need to dig
4. what materials would you recommend?
5. would i need to also build a retaining wall due to the drop that will happen once i level it down to the lowest point? as im only going to level about a metre from the house so there will be a drop.
this is a example ive drawn up of what Id like to achieve. either a retaining wall and pavers with french drain underneath OR just the pavers and french drain
Pic 2 - Retaining wall to hold up sloped area
Pic 3 - no retaining wall but then there will be a drop
Thank you and apologies if this is a very long post. Im very excited to start a new project and any advice would be much appreciated.
