Hello, the front step which is the bottom of the door frame is merbau and is oiled with Intergrain Universal Oil. The part on the outside of the door is weathering a bit faster than the inside. It faces West so gets lots of weather. We think its due for a reoil soon and just want to check the process. Does it need a light sand and then the oil application? Do we need to scrub it with the wood cleaner and wipe it down with water such as with a cloth as its not possible to use the sprayer. We cant work out from the instructions on the tin the process to get the best result and also how to have the outside which is more worn from the elements look a bit more like the inside. Thanks
