So I had my fascia replaced recently and the gutter reinstalled. Sadly, rainwater in pools in the middle of the gutter (about 1.5cm of water at its deepest).
The length of the gutter is about 9m. The difference in slope between the leftmost end of the gutter and the rightmost (where the downpipe is) is about 30mm. Both the left and right ends of the gutter (about 500cm each side) have no water which means there is some sag in between them.
I am asking the tradie to come back and readjust but meanwhile (because sometimes tradies disappear...) I was researching whether in the worst case I can do the adjustment as easy as possible.
The bracket style is like this (maybe exactly this):https://www.bunnings.com.au/colorbond-115mm-quad-gutter-external-bracket-classic-cream_p4790522
I understand the gutter just sits on top of this type of bracket and can be easily lifted. (One or two screws hold the gutter flat against the fascia, but there are not screwed through the gutter).
I want to avoid having to remove the entire gutter to reposition the appropriate brackets, so I was wondering if this approach can work:
- Slightly lift a portion of the gutter, to make space between it and the bracket underneath that portion.
- Put some kind of plate between the gutter and the bracket (something between 0.5cm to 1cm).
- Let the gutter rest on the bracket again, but now the gutter will be sitting on top of that thing I placed, so that portion of the gutter is slightly higher than it was. Something like a booster seat for the gutter.
It feels like it should work, but what kind of thing should I place? And I notice the side of the bracket attached to the fascia is not straight but has an inward angle so I wonder if that will prevent the gutter from sitting properly if I put something too thick.
Thanks
