My car lives on a cement floor, uncovered car park. I need to leave a Walker in it between trips. I am concerned re the heat in the sealed car damaging the rubber, foam bits. Any thoughts? I can’t carry it up & down 20 steps each time. thank you.
Hello @Lynda2021
If you have any other questions we can help with, please don't hesitate to ask.
We'll be more than happy to offer advice and information.
Thank you for your response, I feel better about going on with it now. It’s an awkward bit of kit but it works, so on we go! I appreciate your help. It’s probably an odd place to post my question but I am very grateful for the help. I couldn’t think where else to ask! Cheers Lynda
Thanks for your help, I am reassured. Cheers Lynda
Thank you so much for your info. I appreciate your help. I will get the thermal blanket. Cheers Lynda
G'day @Lynda2021
We've been toting a 4-wheel walker and sometimes a wheelchair in the back of an old station wagon for going on 5 years.
Exposed to the sun and eyes.
No decomposing issues or theft.
Cheers.
I believe that leaving the walker inside the car will be perfectly fine. The rubber and foam bits of your walker should be able to withstand the heat inside the car. If you wish to protect it further, you can cover it with an old blanket or towel so that is protected from direct sunlight.
Hi @Lynda2021
I hear your predicament and understand your needs here.
First try to store it on the shady side of your car out of the direct sun through the car window.
Optionally cover it in a blanket or if you want to try a foil space blanket you know the silver foil used in first aid. They are at bunnings for $4 each buy two in case one rips.
Covering it up will also help keep prying eyes off it.
If it is safe to do so open the car window a half inch just to stop the air temperature building up to extremes away from the side weather (storms come from in your area) .
Hope this helps you out a little @Lynda2021
