I was putting up a bistro blind I screwed the bolts in but forgot to put one of the pull strings over and when I went to loosen the screw the bolt won’t come out as the socket or spinners won’t grip the head of the bolt as it’s been screwed just a little too far into the wood is there a way I can fix this so I can get access to the bolt again so I can loosen it thank you
