I would like to Buy one
Hello @SirJames
Thank you very much for the update. That's an excellent idea in regards to chainsaw spare parts. You can put your mind at ease because you are sure that you've got spare parts at home.
Hi Jacob,
Thank you for your reply. I spoke to the Chainsaw salesman at Bunbury store and he showed me the 25.4 cc 12 inch Cheetah saw which I bought. I tried it and I was that impressed that I bought another. The reason for having 2 is that if one packs up you have another and can keep working. The other reason is the broken one can be used for parts and the parts will be identical which might not be the case with a later model.
Many Thanks,
SirJames
I spoke to the chainsaw salesman at Bunbury and he showed me the 25.4 cc Cheetah chainsaw which I bought. I was so impressed that I came back next week and bought another one.
Hi @SirJames,
Unfortunately, there doesn't appear to be an Ozito petrol chainsaw with a 10-inch bar available. I note that there was one available in the past, but it appears to be out of production.
There is the Ozito PXC 250mm (10") 18V Cordless Chainsaw Kit, which is a battery-powered 10-inch chainsaw.
There is also the Cheetah 12" 2-Stroke 25.4cc Chainsaw, which is petrol-powered and has a 12-inch bar.
If you are looking to replace the bar on an older chainsaw, then there is this Full Boar 10" / 254mm Chainsaw Chain And Bar FBCSBC-104340, which is likely going to work as a replacement.
Let me know if there is anything else I can assist with.
Morning @SirJames and @Jason
I vaguely remember a discussion with Mitchell about this chainsaw?
Is it now basically the Cheetah - but with a 12" bar?
https://www.bunnings.com.au/cheetah-12-2-stroke-25-4cc-chainsaw_p0494258
Cheers!
EDIT ; Found the above discussion...
https://www.workshop.bunnings.com.au/t5/Outdoor/Cheetah-Vs-Ozito-tools/m-p/221097#M30234
Welcome to the Bunnings Workshop community @SirJames. We're pleased to have you join us and look forward to reading about your projects and plans.
Can I please ask what is your nearest Bunnings store so our helpful team can assist you?
