A toy box for storing pet playthings made using VJ panels, Pine timber and MDF.
The project
If you're anything like me, you'll notice that the same old dog toys keep making the rounds in the house. Not only that, they end up scattered, as they pull the toys out of the basket. I was keen to solve these two problems at once! I therefore built this cute little doggy toy box to ensure our furry friends get to experience all their toys without scattering them all over the place. This has been a great addition to our home and was such a simple build.
Steps
Step 1
Decide the size you would like the toy box to be. I had a very specific spot that I wanted it to live so it needed to fit there. I also wanted to ensure the top of the toy box was just a little too tall for my puppies to sneak their heads in.
Step 2
Measure and cut the four sides of your toy box using the table saw. Cut the height of all of the sides first as you can set up the measurement on the table saw. Then cut down to ensure the front and back panels are identical, and the side panels are identical.
Step 3
Using the jigsaw (I used a bandsaw) measure and cut the doggy access hole at the bottom. Remember it needs to be big enough for all the toys to fit through and your dog's nose.
Step 4
Using the wood glue and screws, connect all four walls by carefully placing the screws, so as to not pierce the sides. Measure and cut the base using the 6mm MDF, securing it to the base using the same methods.
Step 5
Measure and cut the top, ensuring there is an additional centimetre either side to allow for a slight hangover.
Step 6
Lightly sand all sections, ensuring to remove any sharp corners.
Step 7
Paint the base with white paint using a roller and small brush. I needed two coats to really brighten the white.
Step 8
Spray the top frame with the Bondall spray varnish.
Step 9
Once all components are dry, use a strong adhesive (I used Liquid nails) to line the top section of the base where the top frame will be secured. Press the frame down onto the glue, and allow to dry.
Step 10
Fill up your toy box with all your pups' favourite toys, grab some treats and show them how to use it. Now you can just throw the toys into the top and your pup can get a new toy every time!
Tools and materials
Tools used in the project:
[article footer]
More inspiration for your pet project
Creative member Alicia_Woodwork also came up with a Hamptons-inspired dog ramp.
Alicia also created a matching Hampton-style dog feeding station.
Get more ideas from our collections of Dog kennels and beds, Pet feeding stations and D.I.Y. projects for pets by Bunnings Workshop community members.
[article footer]
