Three mismatched Colorbond fences were updated and made consistent by spray painting with Tabumans paint in Ironstone colour.
The project
I spray painted my old Colorbond fence with Taubmans Sunproof in Ironstone. I had a mix/match of fences, one brand new Colorbond (Ironstone), one an old wire farm fence, and one old cream Colorbond fence. I wanted a simple DIY project that would improve both property aesthetics and value. Painting offers an affordable way to restore the look and extend longevity without replacing a fence entirely. It was also a great opportunity to test my new spray gun as it was the back fence that was going to be sprayed, so if it had imperfections they would not be as noticeable.
Steps
Step 1
The first step of the project involved preparing the surface by cleaning. I used a brush to remove any cobwebs and dirt. I then used some sugar soap and my Ryobi drill with a brush attachment to scrub the fence. I finished off the cleaning process with a gurney/hose.
Note: Some people also recommend sanding the surface before painting. I did not do this, the fence is quite old, warn and has holes. I wasn't repairing so didn't feel the need to go too overboard.
Step 2
I let it sit and dry for a couple of days while I monitored the weather for a nice warm, dry, and wind free day.
Step 3
On the day of painting, I marked off all the areas I didn't want to overspray. You can lay down drop cloths or plastic sheeting along the base of the fence to protect the grass or nearby surfaces from overspray. Use painter's tape to cover areas you don’t want painted, such as posts or gates.
Tip: Be very mindful of the overspray, this is also another reason to choose a wind free day.
Step 4
Thin and mix the paint in an extra paint bucket. For my spray gun I was recommended 10% water in the mixture. I was also told to strain the paint to insure there were no lumps. I did this with the funnel with a filter, but you could use an old stocking.
Tip: Make sure you mix enough to do the whole project so you don't have to stop halfway through and mix again as this may clog up your spray gun.
Step 5
Set up your paint sprayer according to the manufacturer's instructions. Make sure it’s clean and ready to go. Before spraying on the fence, test the sprayer on a piece of scrap wood or cardboard to ensure the spray pattern is even.
Step 6
Spray the fence. I started spraying from one end of the fence on one angle in an up and down motion and worked my way along, then went back and did the other angle. This helps avoid getting overspray on areas you've already painted, and makes sure you get the different angles of the Colorbond fence.
Tip 1: Hold the sprayer about 6-12 inches from the fence and move in smooth, consistent strokes. Avoid stopping or starting directly in front of the fence to prevent drips. Slightly overlap each pass of the sprayer to ensure full coverage. You can adjust the sprayer nozzle for a wider or narrower spray pattern depending on the surface area.
Tip 2: Apply thin coats, letting each layer dry before applying the next. (Once I got to one end of the fence I could start again.) This will prevent drips and streaks and ensure an even finish. If you see any drips or runs I fixed this with the paint brush let it dry and then gave it another coat.
Step 7
Once I finished painting, I thoroughly cleaned my sprayer, and other items. (clean sprayer according to the manufacturer’s instructions to avoid clogging.) After the paint is dry to the touch (but not fully cured), carefully remove the painter's tape and plastic sheeting.
Step 8
Inspect the fence for any missed spots and touch them up with a brush or spray.
Tools and materials
Tools used in the project:
[article footer]
More inspiration for your fence makeover
Bunnings Workshop member KingStreetReno completed a popular fence makeover by spray painting.
Community member NickiC used Dulux Monument and Matrix panels in a Fence makeover and outdoor entertaining area.
Get more inspiration from our Top 10 most popular fence projects, 10 easy fence painting makeovers, and 7 ways to refresh a fence.
[article footer]
