Bamboo screening panels secured with galvanised wire brought Bali-style to a backyard.
The project
After growing climbers on the fence using a Bunnings Workshop idea, getting a fountain from my mate who didn't bother to fix it, and grabbing a clearance Vinayak statue, I felt something was still missing. It was the bamboo fencing.
Steps
Step 1
Plan how many lengths of bamboo fencing you need and purchase them. Though they are advertised as 2m length I found it to be only 1.8m unless you stretch them thin, so plan for that.
Step 2
Use a self-drilling screw and screw it half way in. Do a turn of galvanised wire clockwise (I think it was 1 mm or less thick). You don't need anything thicker than that. Then tighten the screw and the turn will tighten the wire. When going to other end of the fence leave a little slack in the wire that will get picked up when you tighten the screw.
Step 3
Use the wires as the mounting points for the fence and tie them with the same galvanised wire at every 50 cm for it to be sturdy and not impacted by winds. When joining the new bamboo fence there is a chance that the wire used in the fence would be free at the end that you can tie to the other fence on that is already installed (giving it more sturdiness).
Tools and materials
Tools used in the project:
[article footer]
More inspiration for your fence makeover
Bunnings Workshop members kel created more growing room and covered her Colorbond fencing with her vertical garden with built-in watering system.
Community member Shannon used bamboo fence panels for extra privacy, covering the panels with a rose mahogany stain.
Get more ideas from our Top 10 most popular fence projects, 7 ways to refresh a fence, and our Top 10 most popular screening projects.
[article footer]
