Materials
Belt sander sanding sheets 80 grit and 120 grit for the finish
Detail sander sanding sheets 80 grit
Outdoor Decking oil
Microfibre cloth for decking oil
Tools
Ozito 3 piece sander
Steps
Step 1
Sanded back doors with belt sander at 80 grit.
Sanded back detailed part of doors with detailed sander at 80 grit.
Sanded back doors for their finish using 120 grit sandpaper
Wiped down all excess dust from sanding and cleaned up dust in the surrounding area.
Layed down a protective sheet on the decking, stirred the can of decking oil well before using and used a microfiber cloth to coat the doors with oil.
I had a second microfibre cloth to wipe away any excess oil where it should not be.
Gave the recommended drying time of two hours ( did the second coat the following day to give the first coat a bit of time to really settle in)
Only needed two coats of the oil.
Cleaned up
Job done
