I have to remove and move a car port post but the beam it supports has a join exactly on top of the post above it. (I doubt there is a through bolt joining the 2 parts of the beam but I suppose having the join on top of the post was a reasonable method when it was first built). Its a 48 x 200 mm beam
Can anyone recommend a suitable way of joining the 2 parts of the the beam, like some sort of bracket or length of steel with bolt holes that could bolt across the join. The various sorts of brackets i have seen at Bunnings, in the section with rafter hangers and the like seem too light - there are some lengths of solid hot dipped steel but they are less than 300 mm long with only 3 bolt holes with one uselessly in the middle.
Oh similarly there is a rotten section i would like to splint with something suitable
Any thoughts gratefully received
