Hello Community,
I built a small screening with gate to divide an open area using Specrite 1800x900 alternating slate fence panel, pryda bolt down post support (one bolt) and 90x90 cypres dar post. M10 Ankascrews 100mm were used.
The width of the area is 2800mm intended height of screening is 1800mm. The surface is concrete. the post were 1700mm apart and fence panels were bolted on it. To minimise I have used two panels horizontally to make it 1800mm between two posts. I have noticed a sag in the post towards the panels, yes, they are heavy. Also, the posts have sway motion and wobble.
I am guessing it is because the pryda post support is not correct for this application. please suggest what kind of post support or bolts I should use to make them sturdy and rock solid for windy area.
