G'day folks'
Today i fitted a wall mount for a garden hose to a concrete brick wall and just was curious as to where I went wrong. The steps I took were as follows:
- Found appropriate spot-on wall for wall mount.
- Chose the smallest drill bit I could to drill a mark in the brick through the wall mount. For this I used a drill driver.
- I then had to swap over to a hammer drill (as my drill driver was not powerful enough the penetrate the wall) with an 8mm bit which I marked with tape to match the depth of the plug going into the wall.
- I then inserted the plugs with a mallet as well as the wall mount and screws.
- Job complete.
The problem I had was only two of the plugs were lined up when I went to fasten the screws. Is there anything else I could have done to prevent this? Or was this simply the drill wandering due to inexperience?
Regards,
T.
