Hello,
I would like to install a curtain rod on the ceiling going halfway across the pictured opening, to hang lightweight curtains.
I know that when installing load-bearing stuff into the walls, you should do it at a place where there is a stud. Are there similar studs in the ceiling, and if not, is there any workaround to attach the curtain rod?
Thank you
