Hi all, I'm working on remediating rust off the below galvanised steel post/bases on my alfresco and entry eaves. They are 10 years old and are partially submerged into sand/dirt onto a concrete footing measure 500mm below my pavers. Have had a building inspector check the structural integrity of both posts and are fine but need some rust remediation to extend their life.
I have angle grinded the surface rust off these posts with flappy discs and wire wheel, cut off the nuts which I spent a week of spraying wd40 on everyday whilst using a socket to loosen from the rusted threads. I wasn't successful so carefully used a cutting wheel and cold chisel and hammer to crack the rusted nuts off the threads and have replaced the M10 nuts with new ones as below.
I have treated the rust at the base of the post/welds and at the footing level twice with rustbuster gel for 2 days and happy with the result.
Finally, a builder has told me to use epoxy resin to seal the post base and footing but cannot find any suitable 2 pack epoxy solution that fits my project. He suggested ramset epoxy paste 1210 but ramset no longer produce this product nor have a replacement product for this.
So, I was hoping someone here could help suggest an epoxy resin product to help seal the post or suggest another way of sealing the galvanised steel and making it watertight prior to priming the post and painting it. I have Dulux Metalshield All Purpose Primer and Dulux Weathershield Top Coat.
Thanks in advance.
- n.
