Can I insulate my shed and if yes how?
Hello @japbrizuela
Thank you for sharing your question about insulating your shed. It is a very popular topic, and I suggest having a look at this discussion - How to line and insulate Colorbond garden shed? by @adam_b. In the discussion, I suggested building a timber frame to hold the batts in place. Once the bats are secure the wall can then be covered with your preferred wall liner such as plywood or OSB board.
My team mate also suggested to install a vapour-permeable sarking directly to the inside of the Colorbond walls and ceiling, especially on the walls you can’t access from the outside. This will help keep wind-blown dust, moisture and insects out while still allowing any trapped moisture in the insulation layer to breathe and escape outward. It also gives you a clean surface behind the insulation, just in case anything ever leaks.
I also suggest having a quick look at some of the past discussions:
