This is part 3 in the saga of putting up a Lifetime shed. See part 2 at link below…
I thought I'd post this separately because it's a different issue.
I've now put the shed up. It looks pretty good overall, but when attaching the last 2 panels of the roof I found it was quite a bit out of alignment (maybe around an inch), so I had to put a temporary wedge on the front right corner to align everything. After putting on the skylight panel I removed the wedge, and the front right corner remains a little raised + the doors are very out of alignment and one of them won't close. So, I guess a wedge is needed to be installed permanently to keep it in alignment.
I'm not too sure why it's so out of alignment because I levelled the base. Perhaps it's a combination of the base not being 100% level and it being a plastic shed.
I'm not willing to take it apart and re-do it because A: I'm not really sure what I did wrong, and B: it was a right pain to get it up in the first place.
So I'm just looking for advise on the best permanent wedge I can use. See the photos below. A significant height is needed to keep it aligned (not just a single shim as provided with the shed.
I haven't secured it to the base yet because I'm waiting to get a better wedge in (as opposed to using all four of the provided shims).
Any advice is appreciated.
Cheers,
Stephen
