Hi. I’ve posted elsewhere and no solution yet. I’m trying to see where can I put a dishwasher in this small kitchen and how? No luck getting a tradie to help me or even quote me so may have to DIY.
Hi @sarah20000,
In a kitchen like this, the most practical location for a dishwasher is typically in the cabinet space directly next to the sink, in your case the left corner looks like the best option. This is because there is definitely a water source and drain present so a plumber can modify them to allow for your dishwasher.
The existing cupboard in that corner would need to be modified or removed to accommodate the size of a dishwasher, as they require a standard opening and adequate clearance. This may involve simply removing the door and base of the cabinet, but you would need to see what the requirements of your specific dishwasher are.
You’ll also need access to and power. If there isn’t an existing power point nearby, this will need to be installed by a licensed electrician.
While you may be able to handle some of the cabinet modification yourself, a licensed plumber (and electrician if required) will need to assist with connecting the appliance to ensure everything is installed safely and compliantly.
If you’re having trouble finding someone, try searching for “dishwasher installation near me” as some installers specialise in retrofitting dishwashers into existing cabinetry.
If you still have no luck, we could certainly assist further with modifying the cabinet to fit your chosen dishwasher, but the plumbing and electrical will need to be done by a licenced professional.
I thought so too, but people did point out. I would not be able to stand over the sink rinsing and placing everything into the dishwasher. I would not have space to do that. I would have to rinse place it on the counter move away and then go back and place everything on the counter into the dishwasher. I have heard of people placing them under cooktops, especially when they are induction ones because they aren’t very deep and they’re fully enclosed in any event.
I have had absolutely no luck with any trades people willing to support me with this endeavour so if you could please support me with the do it myself options? I need recommendations on how to cut into the tile underneath regardless of where I place it. Thank you.
II’m not sure if you were looking carefully enough, but there is tile at the bottom that would have to be removed because no dish washer will fit otherwise. I am prepared to do that.
I can certainly support you and offer guidance with modifying cabinets, but I can't help with anything electrical or plumbing. If any plumbing or electrical modifications need to be made, then you would need to contact a licenced professional for these. Considering there is no dishwasher at present, then there's a good chance this will need to happen, and it would be best to do this early on as they will help to clarify what is and isn't possible in the space.
While installing a dishwasher under an induction cooktop it’s not straightforward due to clearance and heat separation requirements between appliances. If those requirements can be met, it may be possible, but you would need to carefully check both manuals and speak with a licensed electrician to ensure it can be done safely.
Considering the workflow, is definitely a good idea, but we also need to make sure that it is possible with what you've got and what you plan to install.
In terms of the tiles, they can be removed, but it does need to be done carefully to avoid damaging surrounding cabinetry or services. This involves scoring the grout lines with a multi tool or grout removal tool, then using a chisel to lift the tiles. There may also be a cement sheet or substrate underneath that needs to be cut back.
Once the tiles are removed, then the base of the cabinet needs to be removed so the dishwasher can sit on the ground. This would likely just involve cutting either side of the bottom shelf and removing it, but there could be some nuance to it. If you had some photos you could share, I could certainly provide further guidance.
Allow me to tag our helpful and knowledgable members @Nailbag, @Dave-1 and @Noyade to see if they have any advice they can offer.
Please let me know if you have further questions or need specific advice. I can certainly continue to assist you to get a plan together.
Good Afternoon @sarah20000
Breaking the job down into smaller sections is how I work out if it can be done and if I can do it or need some trades.
Looking at your kitchen I am thinking of the cupboard to the left hand side of the sink is approximatley where a dishwasher could fit. Tho that means you will be loosing access to that area of storage. (you could re-locate the stuff in those cupboards to under the sink and so on)
The first thing id be researching is looking at dishwashers that you like, heading towards a smaller profile to fit the space you have pre measured. The plinth that the cupboards are sitting on (the bit behind the tiles) may need a bunch of work done depoending on how the bench has been put together.
The water and waste can travel from the sink to the dishwasher through the cupboards (or even under the plinth depending on the makeup) The power can be routed along the same area (in conduit to a new power point) you will need a sparky and a plumber to do this.
You could check what is behind the tiles from the rear (dining room area) but cutting a square in the base plaster (hopefully)
You could check what is under the kitchen bench under the sink if you are lucky by seeing if theer is space to view underneath where the drainpipe goes down through the bench. (sometimes the hole isnt the same size a sthe drain pipe)
1st step measure the spaces
2nd step check models and sizes
3rd step check requirements of the actual dishwasher you choose (just in case, waste pipe length ect)
4th step find out the underside composition of the bench
5th step, work out how to cut through the plinth and also how you would remove the timbers (we can help with ideas for that, requires photos)
6th step retrofiting the smooth edge around the dishwasher.
Problems that may stop you -
The cupboards on the left, I am guessing the one near the sink is 600mm, then the drawer set another 450mm. You may loose both of these areas to gain space you need. The drawers could be moved but by this point its a fairly major revamp.
The plinth may be holding stuff in place, It may not be wise to cut.
As an alternative to not being able to fit a dishwasher I have seen above the bench versions.
Hi @sarah20000
Just a small point, your thinking about being able to rinse the pots etc before you put them in is basically wrong as you don't rinse the dishes before putting them in the dishwasher as you will waste more water than just washing them by hand.
Hello @sarah20000
Looking at the existing space that you have, you might be able to install a https://www.bunnings.com.au/mistral-45cm-stainless-steel-9-place-setting-dishwasher_p0959887 under the sink. But this will involve changing the sink you currently have into a righthand bowl with a left drainer. The dishwasher is a 450mm compact model and not a standard 600mm width, if you wish to have a 600mm wide dishwasher a cabinet or drawer cabinet may need to be removed on the lefthand side of your kitchen based on the picture you've shared.
There is also the option of an https://www.bunnings.com.au/esatto-55cm-white-benchtop-6-place-settings-dishwasher_p0429650 if you're open to that option.
Hi Sarah,
Adding a dishwasher is going to be at the expense of something else, plus a few other complications. 1. The only space I can see is on the left side. You need to allow 620mm for the opening. 600/605mm for the washer and space either side to slide it in/out.
2. The sacrifice will be the drawers in their current location. They would need to move to the left and sacrifice the cupboard space. The right door would need to be reduced in width or change both doors so they are the same size to suit the new opening. A thinner dishwasher may fit, but you will still need to allow clearance away from the back wall cabinetry door handle under the sink, an extra 20mm for clearance either side, and then again you might be into drawer space. So, might as well go a full size model.
3. Kicker tiles will need to be removed and replaced as required. Matching these old tiles may prove to be difficult. The easier option will be to replace with the same size and use tile paint to paint all the tiles so it all matches. I would select white to match the cupboard doors rather than the floor which, will provide a larger feel to the space.
4. An electrician will need to access power from the GPO behind the kettle, down the internal wall and run through the back of the cupboards to a surface mounted GPO. An easy job.
5. A plumber will need to run both cold water and waste /drain piping back to the connections under the sink. A lengthy job but doable.
The entire project is achievable, though the modification of the cabinetry will be challenging unless you're a very experienced DIY'r. Plus you will need a couple of specialty tool. So, maybe shopping around for a handyman might be an easier person to find to tackle this. They would need to be skilled in this type of cabinetry work. You could post the project on Air-Tasker and see who pops up. It will be hard for them to quote, so you might need to agree on an hourly rate with their best guess on how long.
Good luck and keep us in the loop of the progress.
Nailbag
thanks for all the help so far everyone. I’ve been busy trying to get a quote of someone so I can compare.
It looks like where the drawers are would actually be the best spot. So the idea is to move those to the right. They would then be on the wall on the left side of the sink.
The dishwasher would go in the hole left by them.
See below/
The idea of being it would be awkward to not be able to stand in front of the sink and try to load dishwasher. So where the drawers are would be a good spot. Now if it would be a matter of putting in a side wall and installing the runners to use the drawers in the right spot. I would just need to reinforce where the drawers go. Some help with that would be great and anything else. Thanks again.
Re-using the drawers is an excellent idea! However, placing it next to the cabinet on the right side means that you'll not be able to access the corner unless its open from the cabinet on the sink side. I don't see any issue with installing a side support panel inside the cabinet to support the runners and the drawers. A fixed cover panel would need to placed beside the drawers to cover the gap.
Have you checked the width of the drawers as the opening they would create does not look wide enough for a standard dishwasher (going by the apparent size of the tiles).
