Many of us have had remote controls get "sticky" keys where pressing them doesn't always (or never) work. and a suggestion on another post by made me think of posting this.
I work/ed in Telecommunications and used to have to refurbish telephones in order to maintain customers and phones with membrane keyboards (rubbery keys) are the same as remote controls. The issue that stops the keys from working is as follows (you can skip ahead if you aren't intrested in the technicalities).
The rubberised keys have a point on the back of them that has carbon impregnated in it. compressed carbon is a good conductor that when it is pressed on the circuit board behind it shorts out the tracks on the circuit board and that is how the remote knows you have pressed the button. the issue is that the manufacturing process doesn't permanently lock in the carbon and over time molecules of carbon migrate to the surface. Thing is, uncompressed carbon is a very poor conductor of electricity and so creates a resistive coating on the back of the button and the surface of the circuit board stopping it from working correctly.
And so to Eric's trigger, he recently mentioned Isopropyl Alcohol for cleaning a tile surface before sticking a laminate to it and that is what I have always used when fixing keyboards. So if you feel confident dismantling a problem remote, you can clean both the circuit board and thoroughly clean the back of the membrane key pad (don't overdo it as you could rub all the carbon away with some of the cheaper remotes) then reassemble and see how well it works.
https://www.bunnings.com.au/diggers-125ml-isopropyl-alcohol-125ml_p1564443
Suitable sized screwdriver
lint free cleaning cloths
Disassemble
Clean
Reassemble
Test
