Hi all
So I was screwing a screw into an interior brick wall, but the screw was longer than the hole I drilled. As a result I damaged the plaster behind the paint and the paint blew up into a bubble (note: the photos are after I pushed the bubble back down, so it was actually a lot bigger).
My question is, do I NEED to repair this? I'm wondering if there will be any significant consequences down the road if I just leave it as is. Honestly I'd rather not go through the whole repair process (it's a 1950's double brick building, so there's probably about 5 layers of paint I'd have to remove here before I get to the damaged plaster). Also when I tugged on the screw when it was in the wall anchor, it still felt super stable so I think it's still structurally sound?
Other relevant details:
- 8 gauge, 30mm screw
- Will hold less than 5kg
Any advice appreciated! Thanks all
