Okay so I'm a novice at tile cutting which is becoming obvious as I'm trying to cut my first lot of tiles! Part of the problem is that the tiles are rectangular so 160mm long and 52mm wide (and are being laid vertically so the short end is horizontal). Even if trying to cut in half (thought I'd start with an even width) they are breaking horizontally across the tile. I'm using the DTA 300mm Tile Cutter but maybe that's just not a good enough product as well as my inexperience. I do have a multitool and a diamond blade so that's my next thought but any guidance re the correct use of the tile cutter or assistance would be appreciated. There are lots of videos and it looks easy enough but obviously not! Thanks.
