Every time some liquid goes into the toilet bowl even without flushing (I have tried as an experiment), a clear dripping sound starts. It sounds like water hitting a surface or dripping inside the wall. This noise lasts for about a minute or two every single time. It feels annoyingly loud at night especially when I just want to get back to sleep after using the en suite.
What I know:
•No visible damage: There are no water stains on the walls, no puddles on the floor, and no damp spots around the bottom of the toilets.
•No smells: There is no bad smell or sewer odour.
I have tried:
- Get a plumber replaced the flush valves in both toilets. This did not fix the noise. He thought there might be a leak under the house. However, there is no access to get under the floor, so he couldn't check and left.
- Get a second plumber to put a camera down the outside sewage pipe. He didn't see any leaks. He thinks that because the house is built on a slope, the pipes are possibly at an awkward angle. This might be causing water to drip slowly or echo inside the pipe after a flush. He suggested me to leave as is.
I am wondering if there's any way to find out what's causing this or any suggestion for a fix? Many thanks!
