Hi all,
I am hoping to add some secondary glazing to a few of our windows with 3mm acrylic panels and magnetic tape, similar to the below link:
To fix the panels into the window frames, I'll need to add some internal structure as the current frame doesn't have a sufficient "lip" for me to attach the magnetic tape and panels to (see below).
To add the internal frame, I'm considering using 18x18 moulding (either Pine or PermaTimber) cut to size and installed into the existing frame but not quite sure how best to attach this? Would timber glue be sufficient, noting I'll need to push on the magnetic tape adhesive pretty firmly, or should I use nails with timber glue just at the corners?
Any other tips on how to make this internal framing and make sure it fits well within the existing frame would be appreciated.
Thanks!
