I want to secure a metal plate to a rock, what do I need to use to do this securely?
Cheers
Barry
Hello @bschebella
Can you please provide us with a little bit more information about what kind of rock you are attaching to, is it a flat surface, round or irregular? What kind of metal plate are you using? Is there any force being applied to the metal plate? As soon as you give us the details, we'll be able to provide you with proper recommendations.
Hi Barry (@bschebella),
Without knowing the exact circumstance, the basic method of attaching something to a stone is to use masonry anchors, which come in a few different styles such as https://www.bunnings.com.au/products/building-hardware/fasteners-fixings/wall-floor-anchors/sleeve-anchors , https://www.bunnings.com.au/products/building-hardware/fasteners-fixings/wall-floor-anchors/screw-bolts or https://www.bunnings.com.au/products/building-hardware/fasteners-fixings/wall-floor-anchors/chemical-anchors .
All of these options will require you to drill a hole in the stone first, which can be done using a rotary hammer drill with a masonry bit in the correct size for your anchor.
If the surface is uneven, things like washers and packers can often be used to even out the attachment.
When you are able to get back to us, we can certainly assist with some more specific recommendations.
In the meantime, you might like to check out https://www.bunnings.com.au/diy-advice/home-improvement/walls/how-to-install-masonry-fixings for some basic guidance.
If it's just something like a memorial plate - Selleys Liquid Nails Rapid Cure has never failed me..
Cheers.
Hi @bschebella,
Just checking in to see how you ended up going with securing the plate to the rock. There were some good suggestions above around masonry anchors and adhesive options depending on the setup.
If you haven’t had a chance to tackle it yet or ran into any issues along the way, please feel free to reach back out and we’d be more than happy to help further.
And if you have completed it, I’m sure others would be interested to see a photo of the finished result as well.
Thanks guys,
It's actually the plate off my Grandparents headstone which the Cemetery was going to throw away since the lease had expired & their only remaining loving son, my uncle said he didn't want, nor did he tell any of the remaining relatives so I took it & thought I'd attach it to one the big rocks in our backyard that look like Granite to me.
Thank you for that extra information. The plate should anchor nicely with either the suggested anchors or adhesive.
