Hi Everyone,
I'm looking for any advice about what to use on the annexe of my onsite caravan. The annexe roof leaks, and I've learned from previous experience the simplest, most effective solution is to roof over the existing structure. Previously (on another onsite van I owned) I installed a roof of corrugated iron over treated pine battens/rafters, attached directly onto the roof, but in this instance I'm unable to do so without a lot of additional costs (barge boards, fascia, guttering and down pipes). So I'm looking for the most cost effective method of covering the roof. Tropical rooves don't interrupt all the ingress of water, so that's not an option.
The existing roof is made of sandwich panels, often referred to as refrigeration panels. (They're basically just 30mm polystyrene clad on both sides with thin aluminium). It's a sloping roof, not gabled or complicated in any way. I'm thinking maybe just high pressure washing the roof, then adding another sealed layer of the same panels might be do-able. Alternatively, are there any flat sheet metal panels which might be able to be installed over it? I could use an adhesive sealant like SikaPro, plus screws to attach it. I'm sure there's other options I don't know about, and that's why I'm asking here.
If anyone has any experience with this sort of thing, or roofing in general, I would be very grateful for your suggestions.
Thanks very much.
This isn't the van in question, but the roof looks much the same
