Hi I have these very old windows in my apartment. On windy days, air can come through the window. On the bottom I have a seal but wanted to see if there were any other suggestions on how to seal around the full frame. I have multiple of these windows so would be keen to try and seal them all and also then hopefully act to reduce any noise too. Photos below.
Thanks
Hi @eagboola
There was a discussion on a solution for this just recently, see here…
https://www.workshop.bunnings.com.au/discussion/342783/how-to-add-sub-frame-to-window-for-secondary-glazing
Hello @eagboola
Thank you for sharing your question about sealing your window. I suggest having a look at the https://www.bunnings.com.au/raven-5000mm-rp59-white-self-adhesive-window-and-door-weather-strip-white_p3961089 or the https://www.bunnings.com.au/moroday-5m-black-self-adhesive-special-weather-seal_p0127884 . Both are designed to fill gaps and prevent wind and rain from passing through.
I also suggest having a look at this discussion - How to add sub-frame to window for secondary glazing? by @lm4. It's a great example of how to achieve a D.I.Y double-glazing effect without the high price tag.
I also suggest having a look at this guide:
@EricL thanks Eric. My window opens just upwards but I think around the frame it is old and there may be air coming through. Is there a way to try and seal around the frame itself not just the opening at the bottom? Would the weather seals work for this?
I propose closing the window and observe where the window and frame meet. This "gap" around the window generally is where the wind is passing through. Your goal is to use a soft sealing foam such as the weather seal to stop any wind from getting through. My best advice is to look at the frame and make sure that it is flat and totally clean before you apply the weather seal. I also suggest wiping the surface with https://www.bunnings.com.au/diggers-125ml-isopropyl-alcohol-125ml_p1564443 to remove any oil or grease that might have settled on its surface.
