Hi There,
so im about embark on a BBQ build in our courtyard. im pretty confident with what im going to build but I did have a question about the cut out area where Iwill be placing the BBQ itself. ill be making a concrete bench top with form ply etc… and using fibre cement sheet in the cut out section. my question is, as my area is open/exposed to weather and not undercover, do I need to seal or waterproof the fibre cement sheets? is it ok for it to get wet? do I seal it so nothing gets in but then thats probably not great for allowing heat and moisture to get out. or lean it so water drains out?
Any advice would be greatly appreciated.
Cheers,
Tony.
