I'm looking into pouring my own outdoor kitchen workbench and splashback with either Dingo High Strength or MaxPro mix. Can you pls advice which one is better suited.
The plan is to pour 40mm thick slab in a formply form, with reinforcement steel, and then turn it over for a smooth surface finish, before sealing.
About 3 square meter in total, 40mm thick, across multiple pieces, the largest being 1 square meter.
In the products spec. sheet (including within the sheet) and the bunnings website are conflicting information about the yield of the concrete mix bags. In my calculation, everything between 0.208 to 0.275 square meter per bag at 40mm thick. So I don't know how many I will need.Is the yield different between the two products?
