The plan was to create an outdoor area for hosting friends and family, while maximising the level areas so both kids and adults had plenty of space to mingle and enjoy. To achieve this, I built a retaining wall that created two usable levels and incorporated a curved bench seat into the wall for additional seating and to match the style and character of my house.
I got a quote to have the initial slab laid, but it was nearly my entire budget. At that point, I knew I had to go DIY.
With no experience driving excavators, concreting, laying bricks, or building retaining walls, I was definitely worried I had bitten off more than I could chew. It was a pretty daunting project to take on, but I was determined to give it a crack and learn as I went.
Besser bricks
Concrete
Motar
Reo
Sweat & Elbow Grease
Chemset
Timber for form work
Humans
Excavator
Shovels/spades/picks
Impact drivers
Concrete truck
Let the digging begin... With the help of my dad, we dug the footings out for the slab and retaining wall.
- Step 2:
Form it up... we then formed up for the slab (didnt take a final pic of all the crusher and reo in place). Had to raise the drain pit and add channel drains in. We set the drains just proud of the concrete as we are tiling this area and want the drains to be just below the level of the tiles.
- Step 3:
Concrete! Wayy too much to hand mix, got a truck and pump truck to get this done.
- Step 4:
Let the bricking begin!
Before we could start laying we had to do the tedious process of adding the reo bars in. To do this we SDS drilled holes and chemset the bars in place.
As we couldnt use a string line on the curve, we welded up a frame that pivoted from the dead centre.
- Step 5:
We then modified the pivot frame to build the course for the bench seat.
- Step 6:
More dirt and form work.
Next we dug the footings for the stairs and rest of the retaining wall.
We plumbed in the drainage pipes that will hook up to the agg pips that will go in behind the wall
We then formed this up with 2x4 and trench mesh.
- Step 7:
More concrete...
Poured the footings and the tops of the bench seat & corefilled the curved retaining section
- Step 8:
Back to the bricking...
- Step 9:
Current Phase.
We have core filled the new section of retaining wall.
Waiting on a renderer
Still need to water proof the back of the wall and install aggs and back fill with gravel
Will post a final pic when finished
