Hi Crew
I have gaps around my sliding doors. This is a new purchase home for me so no context as to how or when they were installed or what may lay behind the holes.
Using your previous advice, I tried a piece of gap filler rod to see if it was big enough, and lost it into the cavity.
Some gaps are small and a bead of gap filler will work. Some are larger and seemingly just a deep void.
I've cleaned them all out, removed old silicone, etc. I've attached photos of the top but there's gaps top and bottom. They're wider at the edges, probably because the original spance wasn't quite square and a modern, square door was installed.
Any advice?
thanks in advance.
