Hi
Is the a way to replace Pinnacle 1830 x 1200 x 410mm 5 Tier Adjustable Shelving Unit shelves with wire shelving?
Hi @Jamee,
Unfortunately, there are no premade wire shelving options available for the https://www.bunnings.com.au/pinnacle-1830-x-1200-x-410mm-5-tier-shelving-unit_p2760459 . You could theoretically customise something to fit, however you would do so at your own risk as these shelves are not designed for this specific purpose.
There are options for 5 tier wire shelving units such as this https://www.bunnings.com.au/pinnacle-1800-x-911-x-450mm-chrome-5-shelf-wire-storage-unit_p2760373 , but as you'll notice, the frame is designed differently to accommodate the shelving units.
You could also check out the options from https://www.bunnings.com.au/brands/r/rack-it , which can be used to create your own custom shelving. Have a play with their planner and see what you come up with.
Allow me to tag some helpful members to see what they think @Dave-1, @R4addZ and @Noyade.
Good Afternoon @Jamee
I havnt seen anything that would work off the shelf, as @JacobZ has mentioned, you could custom make something but I dont know if I would trust it with that style of shelving frame. I can say that the Rack It shelves that @JacobZ mentions are brilliant. I have been using these at work for years and they stand up to a beating. I havnt used teh wire inserts but the mdf board. I do have to flip the mdf every couple of years as it does slowly deform into a low U but its an easy fix.
Hi @Jamee
The question has to be, what purpose do you need the wire shelving for?
Looking at the Bunnings site - they have wire shelving. If this is a new purchase - could you return the current one and replace it?
