I have a shower head that I am looking to replace and I am wondering what tool I would need to remove the holder from the wall?
Thanks
Hi @BP22183
Looks like a fairly large allen key to me, however are you sure it doesn't just rotate off as it is probably screwed onto a fitting in the wall. The allen key part may just be a removable plug for if you want both a fixed head and the flexible hose.
Thanks for the response. I did try that. But no luck. It seems to be about 10mm, so I guess I’ll need to get an M10 Allen key to get it off
Appreciate the help
Hi @BP22183,
I agree with @R4addZ that it seems to be a large hex head fitting, which can be removed with an allen key.
While replacing a showerhead is generally considered unregulated plumbing work in most jurisdictions, meaning it doesn't require a plumbing licence, it is always worth double checking your legal requirements before proceeding with any plumbing adjacent work.
I mention this because this fitting looks a bit different to a standard screw on showerhead like shown in https://www.bunnings.com.au/diy-advice/home-improvement/baths-showers-toilets/how-to-replace-a-shower-head . I'd suggest you take all necessary precautions, such as turning off the water at the mains, and having buckets and rags close by. If you find upon removal that the fitting doesn't look how you expected, or that it needs modification to fit the new showerhead, then you should reattach the fitting, and contact a plumber for assistance.
If you do require assistance from a plumber, then you might consider using our https://www.bunnings.com.au/services/in-home/tapware-shower-mixer-installation .
Let us know how things go and if you require further assistance, please don't hesitate to reach out.
Thanks Jacob - I wasn’t planning on completing the work myself, was just trying to get an understanding of what I would need to purchase as a replacement
Thanks for all the assistance
A recently installed Bunnings Estilo shower rail at home also required a 10mm Allen key for the mounting nipple - @BP22183
