Hi. I'm planning on mounting two shelves of 1400x175x20mm in the kitchen - oregon timber. The shelves will hold glass pantry jars - so between 15-20kg per shelf. I've got Carinya black hanging lipped angle brackets 185x185, three per shelf, so spaced about 65cm apart. The walls are cement rendered engineering red brick. I was planning on using 6x60mm dynabolt masonry anchor sleeves, however it seems the bricks are 3-hole, i.e. once I've drilled 25mm in, I hit air. Would love advice on what anchors / screws to use - i.e. do I need to go the chemical route, or would a 60mm, or even a 34mm countersunk dynabolt masonry anchor sleeve work?
Thanks
