Hi! I'm wanting to turn one of our spare bedrooms into a home library. I've been watching so many YouTube videos and everyone in the US seems to have access to great quality cabinet and/or furniture grade plywood for quite economical prices (given they use it for everything)...
In rural NSW, we don't have anywhere near the variety of options, so as I'm completely opposed to going the famous IKEA Billy bookcase DIY as it's so expensive to do here in Aus (and for that price I don't want to also have to refinish, prime and paint them), I figured I can grow some skills and build myself from scratch and save quite a lot of money - but I'm stuck on the best material to use.
I'll be building my bookcases separately, so they can be moved down the line if I ever need to, however I'll be doing face frames etc. to make them look built in.
I'll be alternating between widths of 40cm and 80cm (with the intention of having a finished product similar to the attached screenshot).
My DIY bookcases will be ~2.4m tall, however depending on the material I end up using I can either do full height cabinets, or I'm considering taking a leaf from IKEA's book and doing the main shelves at around 1.8m tall, then building some ~60cm tall 'extensions' that sit on top (if I'm using sheets/panels that are shorter than 2.4m). See example below:
I'll be putting everything together using pocket holes/screws - and am considering routing out the sides for shelf placement (as I don't like the look - or the time needed to include and hide - adjustable shelf holes). The finished bookcases will be painted and I'm wanting a flat/smooth matte finish.
I'm not interested in using MDF for the dust aspect during building and long term shelf strength etc.
I'm currently tossing up between plywood and the multi-use desk panels available on the Bunnings website.
Unfortunately, the plywood available from Bunnings in the ~2440x1200 sizes is at best C/D grade and the 'better' graded ply comes in smaller sheets and higher prices, especially for the 18/19mm thickness I'm after.
So I've been basing my plywood plans around this product:
https://www.bunnings.com.au/structaply-2400-x-1200mm-19mm-plywood-structural-cd-grade_p0340167
I don't know how much work would be involved in getting the C/D grade plywood sheets up to a suitable level for a nice paint finish...?
I'm not sure how possible or suitable my alternative is, but for a little more in the overall cost area, I could instead try using some finger jointed multi-use panels.…?
I would either use the 1200x600 varieties, make two "units" and stack them to create each full 2.4m bookcase. Or I could get the 1800x600 varieties, and build the main section to 1.8m and build 60cm 'extensions' to add on top.
What I don't know is how these panels - being finger jointed - will hold up to being cut up and used to build the bookcase carcass, and also the shelves.
I'm looking at using either Pine, Acacia or Hevea, but I don't know which will be the best for what I'm wanting in terms of ease of building with, plus durability and longevity etc.
https://www.bunnings.com.au/specrite-1200-x-600-x-18mm-timber-multi-use-pine-panel_p0419619
https://www.bunnings.com.au/specrite-1200-x-600-x-18mm-brown-acacia-multi-use-panel_p0446778
https://www.bunnings.com.au/specrite-1200-x-600-x-18mm-hevea-multi-use-panel_p0447357
I would appreciate any advice, feedback or help anyone can provide on what the best material would be to complete my project that gives me the best value for money as I am on a budget, but still want to achieve a really nice finish.
If I've missed mentioning anything, or you'd like more details before you can offer advice, please let me know and I'll try my best to answer your questions.
Thank you so much in advance! :)
