Hi, I have a deck in my backyard that is starting to show signs of age. The deck was built using BlackButt timber, and is mainly under a pergola (which provides it with sun and rain protection) - notwithstanding the ends of the deck that are exposed. I have been maintaining my deck with Cabot's Aquadeck decking oil product - which has been good and refreshes the look.
On one of my lengths of timber, the wood is starting to split and there is a small piece of wood that has splintered. I've attached two pictures of the splintered wood - FYI.
The question I have is, what is the best way to remedy this piece of timber, so I have good repair? Should I sand off the splintered piece and replace what gap there is with a wood fill product (please advise on what would work, and do I need to color the fill), and then in spring when I do the annual maintenance on the deck (i.e. wash/oil) would that be sufficient (and blend in with the Blackbutt), or would you recommend a different approach to addressing this? I don't really want to replace the entire plank as that seems an excessive fix.
Thanks in advance for your advice.
Cheers!
Mark
