I have recently started to experience ghost toilet flushing in my home - we have three bathrooms - all with the same toilet/plumbing. I have been doing research, and today cleaned the cistern's which was a recommended first step to remove lime-scale build-up. So far so good!
The next recommended step was to check the flush valve seal to assess if it needed replacing. I have a center flush valve, and understand that within it is where the seal needs to be checked. (see photos of the device)
I read that these devices should either twist (counter clockwise) at the top or need some locking tab released. For the life of me, I can't sort it out and get the top to open so I can inspect the seal to see if it needs replacing.
Have you ever seen this type of fixture before (see pictures), and can you advise how I get to open it to check the seal?
Thanks for your help.
