Seeking guidance on giving these beautiful 100+ year window frames a few more years of life. I had a Queenslander-specialist builder look at them and their recommendation was to replace with new but I think they still have some years in them. Glazing seems relatively secure.
At this stage I'm thinking the steps are:
- Can't see any degraded timber but it's split at a couple of the joins
- Not sure yet about the condition of the putty around the glass - propose to scrape out brittle or cracked material using a putty knife or chisel
- check for condition of glazing points
- Sand back loose paint - rough grit and then smoother
- Patch putty - linsead oil/ prime first?
- Check glazing is secure and put painters tape around edges
- Prime
- Paint with a semi-gloss suitable for windows
Queries in addition to above:
- I think the fixings are brass - I wasn't proposing to remove them to clean - just clean as well as I can as is. So clean those with baking soda and white vinegar paste. Once clean use a clear paste wax.
- Is there anything I can do for the split timber?
- Is there anything specific for replacing/ repairing the putty if needed?
- Any specific tools and products you'd recommend to help with above?
thanks.
