Hello
My house is 1980s brick on slab. All the plumbing is down one side of the house, kitchen, bathroom, toilet & HWS (see photos). Some time ago I did a flood test by taping the drain in the shower, and the next morning some water leaked across the floor tiles to the wall, but the water level looked about the same and it wasn't a lot of water at all. This test was above tiles though, something fixed by new grout or silicone, which I did myself recently. But this doesn't test the integrity of the drainage system below.
About a year ago, a plumber with a good Tramex meter said the tiled floor adjacent to the shower was maximum 99% moisture after turning on the shower tap. He said I needed new grouting and silicone but this is all he did. But what if the main problem is below tiles in the drain below?
It's the potential drain leak I'm worried about. And why I don't want to pay a plumber $$$ for re-grouting & re-siliconing if the expensive problem is the trap / drainage leaking under the shower pan. This was an IP before I bought the house.
Any idea what kind of bathroom drainage I would have? The roof gutter pipe is right next to my bathroom (closest window in photo). Is the gully under the pipe for stormwater or sewerage? I suspect I have no real bathroom waterproofing at all, as this didn't become code until after the 1980s.
I basically want to know what kind of bathroom drainage I probably have and how much roughly it's going to cost to bring up to code. Shower drain is 40 mm and I think it's PVC pipe. Would appreciate any advice. Thank you.
