I am trying to patch this hole and am planning to use
Pfeiffer 15cm Plaster Repair Wall Patch
I used this twice, and both times, after the filler is dried, I will start the sanding process. But usually before it flushed with the wall, I will start to see the patch's metal plate.
Did I do anything wrong, or is the repair with this type of patch suppose to be have a layer protruding out?
