Hello team,
I'm planning to DIY install Peak 5-tread steel stringers to replace some hazardous existing stairs with uneven and tall rises. Not looking for a great fix as we'll likely need to replace the retaining wall in the next 10 or so years.
Preference to install Peak handrails with the steel stringers for look and ease (Peak modular handrail kit or Peak stair baluster kit), otherwise I will just go with timber. Mock-up attached.
My questions are:
- Do the top posts supporting the handrails need some lateral support (such as a short balustrade connected to another post running perpendicular to the handrail), or would the two handrail posts on each side be sufficient? The top posts I plan to attach to a concrete footing.
- Would it be fine to attach the bottom posts to the tread on the first step, or better to bolt to the concrete?
Thanks for your time.
