I have read the previous answers but I am stuck at getting the flush valve out.. any suggestions. The clips at the front were easy to set free but the back ones won't move, even with a screwdriver to pry them out and up..
Hi @BarbaraBlinco,
It sounds like you might not have disconnected the flush pipe nut at the base of the cistern. On the underside of the cistern there should be a nut that resembles this https://www.bunnings.com.au/kinetic-pvc-flush-pipe-ring-and-nut_p4920281 . I'd loosen off that nut and try again.
Let me know how you go.
From my meager toilet experience - you should be able to unhook that square looking plunger column. Once you do this that bridging plastic should come off. You're having issues with this - try WD40 prior. Once out you should be able to rotate counterclockwise the lower end to reveal the seating washer. Lots of 'shoulds.'
Replace.
Are you absolutely sure @BarbaraBlinco this is the problem - not the inlet valve seen on the left?
