Hi all, my sliding aluminium screen door keeps popping off the bottom rail when I slide it open too enthusiastically or when I try to lock it. I think there's two reasons for this. Firstly the glass/screen door frame setup looks to be sagging ever so slightly in the middle of the outside section and when I try to lock it, it pulls the screen door up a little to align to the frame and the roller then pops off the track. Secondly, the bottom rollers are also cracked and unadjustable with a screw driver as the door is probably 20 years old.
What can I do to fix this problem in the most cost effective way? Would getting new rollers on the bottom of the door and lowering them would stop the problem? Or does the sag necessarily need to be addressed?
Also, do you know what rollers these are and how I would replace them? They are all riveted with an adjustment hole on the side face of the door but I otherwise see no other fixing.
Thanks
Snipwhip
