Good evening all!
I am fresh off my first DIY paving project and now want to keep the momentum going and construct a raised garden bed that will line the backyard perimeter fence. I have freshly cleared the area of assorted trees and getting close to figuring out how i will put in a concrete strip footing then select what type of brick/ concrete block i will use. As I am pretty green to concreting and brick laying i have a lot of questions on how i should attack this project.
The Idea:
Build a raised garden bed/ plantar from brick or concrete blocks (then render if i go down this path) onto a concrete strip footing along existing color bond fence leaving a 100mm gap between the fence and the new wall. Additionally planning to paint the color bond fence steel monument. I would like to include conduit for reticulation and power and there will be seating incorporated into the wall using timber sleepers. I plan to do this by narrowing the width of the plantar and having the seat inside the boundaries of the plantar, if that makes any sense. I am aiming to have the plantar 0.5m-ish high and 1m wide. The plantar will stretch 5m one wall, 19m the next wall and 5m the following wall in a U shape. I plan to use mesh rebar throughout the footing and plastic sheeting in the trench. For drainage i was planning on leaving weep holes in the brick work and agi pipe at the bottom of the plantar covered with blue steel for additional drainage. The plantar would then have olive trees and assorted infill plants installed. Lighting to be placed under seating and near olive trees. Reticulation to be installed also.
Initial Questions:
- What width and depth would you make the strip footing for a 0.5m high wall? I was thinking of going 300mm wide and maybe 150mm deep but im being told this may not be adequate?
- I have 2cube of road base i wanted to get rid of, is it a bad idea to mix this with the cement to create the strip footing or am i better off using the road base as a sub base to the footing?
- I am pretty confused on which brick or concrete block to use, some people i speak to say that if i use brick i would need to run a double wall with concrete infill to support the bed if going down the brick route. Others tell me 1 layer of besser sized 390 x 190 x 190 also would not be adequate, would be good to hear suggestions on what block to use. As i mentioned if i go down the brick facing route id probably leave it bare brick, if i went down the besser block route i would be inclined to render it white.
Would be great to solve the above questions so i can make an attempt at getting the strip footing down before returning to work or be informed of anything i am overlooking or havent thought about. I have attached some pics of the backyard area and a design i made using chat GPT, the design isnt exactly what im after but just a ball park sort of look. I would like to have curbed corners for a bit of a sleeker look.
Thanks everyone!
