I'm looking for advice on whether my idea for a cheap, removable dining-table extension is sound, particularly around stability and how best to secure everything.
My existing dining table is 1000mm wide. I want to temporarily extend it when I have extra guests, but I don't have space to store another full-size dining table. I want the extension to match the width or the existing table which is 1m wide.
My current plan is to buy a second-hand 1200 × 600mm folding/trestle table for around $30 and use that as the supporting base.
I want the finished extension to be 1500mm long × 1000mm wide. It will connect to the end of my existing 1000mm-wide dining table and should give me room for five additional diners – two on each long side and one at the outer end.
Rather than using one large 1500 × 1000mm sheet, I want to make the top in two pieces because they'll be much easier to handle and store vertically beside my fridge.
I'm thinking of buying 17–18mm plywood or formply and having it cut into two pieces measuring 1500 × 500mm each.
The two pieces would sit side-by-side, with the join running lengthways down the middle:
1500mm
500mm │ 1500 × 500 panel │
1000mm
The 1200 × 600mm folding table would be centred underneath. This would give the plywood top a 200mm overhang on each side and a 150mm overhang at each end.
The two plywood panels would need to be securely connected together while the table is being used, but I want to be able to separate them afterwards for easy storage.
My initial thought was removable timber battens underneath spanning the join, but I'm completely open to a better or simpler method.
I'm also happy to screw into or permanently attach brackets, blocks or other hardware to the folding table if that's the best solution. As it's only a $30 second-hand table and will be dedicated to this purpose, modifying it isn't an issue. I'm just not sure whether attaching the top to the folding table is actually necessary.
Ideally, I want the two plywood panels to lock together securely and the completed top to be unable to slide or tip, while still being quick to dismantle after use.
I could also use non-slip rubber matting between the folding table and plywood if useful.
A tablecloth will cover the entire thing, so the appearance of the plywood and centre join doesn't matter.
Does this sound like a safe and stable design for normal dining use?
I'd particularly appreciate advice on whether 17–18mm plywood/formply is the right material and thickness, whether the 200mm side overhang is reasonable, the simplest removable way to join the two plywood panels, and whether/how you would secure the completed top to the folding table to eliminate the risk of sliding or tipping.
I'm trying to keep the whole thing cheap, simple, stable and easy to dismantle and store.
