My tiler used the wrong shower base in my bathroom renovation and has suggested an interesting workaround that I'm a bit hesitant about.
Image 1/2: They used a 42mm thick base and so the shower base is visually high compared to the surrounding floor and there is just the thickness of a tile in clearance from base to top of hob.
- Outside floor to top of hob = 60mm
- Inside shower to top of hob = 10mm
Image 3: In comparison, the first bathroom with same floor, plumbing and tiles used the correct 25mm thick base. The shower base is not noticeably higher than the floor visually, and the shower base to top of hob has good clearance.
- Inside shower to top of hob = 40cm
Whilst I'm not stoked on the visual aspect, my bigger concern is water containment, as a 10mm inside lip doesn't give much grace if there is water pooling or a foot over the drain.
The only thing they have offered is to increase the height of the hob - but by building it up by layering extra tiles in, which I can't find info for online. Below are the steps they outlined:
- Remove the existing top tile from the hob carefully, along with the tile adhesive.
- Remove the outside tile from the hob and clean back the remaining adhesive where required.
- Build up the hob to the required height with an additional tile and adhesive layer to add an extra 15mm.
- Check the finished height, level and fall before continuing with the tiling to add the hob sides and final top tile.
- Take care during the work to protect the existing waterproofing.
- Once the hob has been adjusted and checked, the top and outside face will be re-tiled.
Hoping to get some insight from someone with tiling knowledge whether this is a viable solution, and if not what else you might suggest?
Thank you!
