Hello bunners,
I'm looking for something to coat objects with, to give them a non-slip finish.
I've thought of many things throughout the year that I would like to make more grippy without being gritty. Here are some examples…
- The bottom and other flat surfaces of my laptop.
- I carry my laptop around the house with me throughout the day while working; I would really like to prevent any more laptop-dropping and -smashing incidents.
- BONUS SIDE QUEST: If you can suggest a way to make the laptop less easily smashable if dropped, that would be amazing. Like how you put a protective cover on/around your phone. I can't find anything purpose-made online though.
- My computer mouse.
- I bought a mouse that is more upright and supposed to be more ergonomic, but the surfaces of it are so sleek and slippery that I can't actually pick it up to move it to a different position on the desk or anything.
MISC:
- Flat back earrings
- Wondering if there would be something which I could also put on the outside edges of the discs of my flat back earrings. I cannot for the life of me grip onto them effectively to screw or unscrew the damn things to take earrings on or off.
- Craft tweezers
- I use some for fine intricate craft and jewellery making purposes, as well as for working with UV resin.
I live below the poverty line, as so many of us do, so inexpensive would be much preferred — also adhd, so the simpler the better in terms of process, waiting times etc
Thank you so much in advance for your expertise and help; I am quite curious to see what you all come back with!
Further info that the ADHD feels is 100% important to include, but that I wrangled my brain to put as footnotes instead, so the actual postiest bit of the post is more concise and to the point:
Laptop:
- My current and past methods include…
- supergluing waffly-type non-stick matting to the bottom;
- cutting a hand sized piece of yoga mat and sticking that on the lower section of the back; and
- I had the idea of cutting out shapes from rubber dish gloves to attach somehow to the sides and the edges of the surface around the keyboard, but didn't get to it.
- In terms of grip and non-slippiness, the waffle stuff & yoga mat did work pretty well, although the waffley stuff is very much deteriorating & coming off the laptop's underside. :(
- The underside of the newer laptop I have has fan vents on it so I can't cover the whole thing, which makes the waffly coverage flimsier with more edges; hence the deterioration.
- The yoga mat is quite bulky so I'd prefer not to use it all over, it will make my laptop so much chonkier for carrying/fitting in places.
- re: protective case equivalent — I toyed with the idea of cutting very fine strips of the yoga mat to affix to the side edges and corners of the laptop (excluding USB & cable holes etc) but never got that far. Don't think it would stay put very well in those places anyway, would have to be too thin a strip compared to the thickness of the yoga mat.
Previous laptop (was more lightweight)
Current laptop
oh no :(
Bonus tip from me to you: paint little arrows on your USB cables and outlets. No more muddling about looking at where the cable needs to go or which way up; just make the arrows kiss and you're good to go.
Mouse:
- I have currently got patches of non slip waffle matting blue tacked onto it as a "temporary" measure. (it's been a couple of months now at least, and I've been wanting to cover the rest of the surface too in case that helps.)
I'm quite pleased with the resourcefulness & ingenuity of it… It does help, but it's more "less bad" than it is "good," and I still have to think and work way too hard to use this mouse effectively. The waffly stuff sits out to the same level as the scroll wheel, as well, so that makes it surprisingly difficult to locate the wheel for use. It would be really great to have a better, more reliable, less sticky and bulky alternative.
Earring backs:
- I thought of attaching a tiny washer to the outer edge somehow, but I don't know how I'd get it attached securely enough, nor smoothly or whatever so it's not going to irritate the backs of my ears, or the skin behind the ears either.
"The simpler the better":
- Example: I am playing around with a lot of resin for flowers and leaves and jewellery making type things, and there is no way in hell I will ever use epoxy resin. I maintain that UV resin is the only way to go for someone with a brain like mine.
Thanks again!
